adding . on changing tftp alternate option 8845
genaro.ugalde
Dose anyone know how to add the altrnate parameter of TFTP address  on 8845. User  access menu but doesn't now how to add (.) when typing ip address.
Keypad Key Special Characters
One (1) / . @ : ; = ? -_ & %
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8800-series/english/user-guide/P881_BK_C3A802A0_00_cisco-ip-phone-8800-user_guide.pdf
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
5 Replies 5
Leonardo Santana
Step 1
On the Cisco IP Phone, press Applications , choose Admin settings > Network setup > Ethernet setup > IPv4 setup > TFTP Server 1.
Step 2
If you have assigned a static IP address to the phone, you must manually enter a setting for the TFTP Server 1 option.
Step 3
If you are using DHCP, the phone obtains the address for the TFTP server from the DHCP server. Check that the IP address is configured in Option 150.
Step 4
You can also enable the phone to use an alternate TFTP server. Such a setting is particularly useful if the phone recently moved from one location to another.
Step 5
If the local DHCP does not offer the correct TFTP address, enable the phone to use an alternate TFTP server.
This is often necessary in VPN scenario.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8800-series/english/adminguide/P881_BK_C136782F_00_cisco-ip-phone-8800_series/P881_BK_C136782F_00_cisco-ip-phone-8811-8841_chapter_01110.html
Leonardo Santana
Leonardo Santana
The problem is when you are typing the ip address  the user dosent know where is the (.)  key  to enter the ip address  example:
10.1.1.1   doesn't know who to type the (.)
Leonardo Santana
Leonardo Santana
thank you this worked
To enter "." on network settings, you need to use "*" and not "1".
Response Signature
