adding prefix to clid to dial missed call
techguy
Level 4
Level 4
Hi everyone, I have created translation rule for manipulating PSTN digits to internal extension. So it's being used for DID. Now same time we want clid to be prefixed with digit 9 also. Any clue to do it CME?
6 Replies 6
Dennis Mink
stick this on your voice-port, or incoming dial peer
voice translation-rule 2
 rule 1 /\(.*\)/ /9\1/
voice translation-profile ADD9
 translate calling 2
Please remember to rate useful posts, by clicking on the stars below.
Thank you for your reply.
As i told that i am using following translation rule. In this case how can i apply above mentioned tranlation rule.
when 0781234569 calls 12395444 then it comes to extension 1200 and as of now it showing CLID as 0781234569 but i want 90781234569
voice translation-rule 1
 rule 1 /^444/ /1200/
 rule 2 /^456/ /1201/
 rule 3 /^455/ /1202/
voice translation-profile DID
 translate calling 1
voice-port 0/0/0:15
 translation-profile incoming DID
 bearer-cap Speech
Apply the rules Dennis suggested under your POTS incoming dial-peer then?
-Terry
Please rate all helpful posts.
its not working
any one please
I m not feeling the loving here
As engineers we can all appreciate that "its not working" is "not really helpful".
so,  first of all  test the translation and see if it translates in the correct way:
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/61083-voice-transla-rules.html
if it does, then make an inbound test call and debug voip translation and verify if your rule gets hit.
