Adding ringtones on 88xx phones
eliegerges
Dears,
Anyone could help me with detailed procedure to add ringtones on 88xx phones.
Do we need to rename the .raw file to .rwb and upload it on CUCM ?
Thank you
Jaime Valencia
The administration guide for the 88xx series or the particular model you're using, contains a section that explains how to use custom backgrounds and ringtones, have you reviewed that document?
Same for other phone models, the admin guide contains the specs for the images and info on ringtones.
java
if this helps, please rate
See this link, http://usecallmanager.nz/ring-list-xml.html
A RWB file is in raw format, but in 16000Hz instead of 8000 as for the older models of phones.
Response Signature
Also have a look at this document for common issues with this. http://uc-b.blogspot.com/2016/10/cucm-115-custom-ringtones.html?m=1
Response Signature
