adding sip dial peer on CUBE
carl_townshend
Hi all
We have been given a SIP address by our ISP to send the calls to.
They have give us a NAPTR record, and 2 A records.
Would you point the dial peer to the NAPTR record?
also if I wanted resiliency to the ISP, would you just create 2 dial peers with different preferences?
cheers
piyush aghera
I believe you need to create dial peers using A records and as you have two A records, you can create two dial peers for resiliency.
