10-30-2008 06:50 AM - edited 03-15-2019 02:16 PM
During the initial installation of my Unity 4.2 server it was not added to the domain. The Sql is running locally on the server. What is the procedure to now add the server to an existing Domain.
10-30-2008 07:56 AM
unfortunately the only way to change a server from a domain is to reinstall the server.
Renaming a Cisco Unity Server or Moving a Cisco Unity Server to Another Domain
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/unity/42/upgrade/guide/ex/ru_080.html
java
if this helps, please rate
10-30-2008 08:21 AM
It is not currently on a domain, would the same apply
10-30-2008 08:22 AM
yes, that counts as changing the domain from none to something
java
10-30-2008 08:23 AM
How did you install Unity wihout not being in domain? It's not possible.
Chris
10-30-2008 08:44 AM
You're right, it has to be added to another domain
