Adding/Updating digits on Xml file - UCCX Scripting
I'm looking for a sample script, where i can Add or update the digits on Xml file.
for example xml file contains
phone number:
<Number>07654632415</Number>
Scripts will play a message "Enter phone number for call divert on Emergency"
Then the digits dialed after the message should be updated on this xml file.
And the second message should play "you entered .........."
Is this possible
Thanks Shameer
2 Accepted Solutions
Anthony Holloway
You do not need an XML file for something this simple.  You could, but it's more work than needed.
Simply create a plain text file that has the emergency number in it (or start it off blank for that matter).
In your script, you would read the file simply by assigning the Document to a String.
E.g.,
Set file_contents = DOC[emergency_number.txt]
Then, to update it, you would simply use the Upload Document step, using the same filename so you can overwrite it, and for the value you would just use the String variable with (Document) in front of it.
E.g.,
(Document) new_emergency_number
If you haven't worked with Documents much, or uploading them, then you may not know you need to authenticate a user first, which is as simple as creating a User variable and then using the Authenticate User step.  Of course it can be more complicated with caller input authentication and what not, but that's your choice.
Might as well link to this, as it pertains to authentication via scripting:
https://supportforums.cisco.com/message/3856013
Good luck and happy scripting.
Anthony Holloway
Please use the star ratings to help drive great content to the top of searches.
Your Set get_number = new_emergency_number is backwards.
It should be Set new_emergency_number = get_number
Flip that around and give it a shot.  Let me know how it works after that.
Anthony Holloway
10 Replies 10
Anthony Holloway
E.g.,
E.g.,
Anthony Holloway
Hi Anthony
Thanks for the response and pointing me in the right direction.
i worked with writing and uploding scripts before with xml files thanks to your other posts.
I'll try this out let you know if i face any issues.
shameer
Hi Anthony
The repository user authentication works fine
and
Also I can read the numbers on txt file and able to transfer the calls to that number.
But couldnt find a way to replace/update it.
please see attached screen for the step,
Can you please give me proper steps to accomplish this
shameer
It looks like you are missing two things within your Upload Document step.
1) You are using the repository account xml document as the contents of the new file to upload, and you should be using the (Document) new_emergency_number trick instead.
2) You are using the file_contents variable for the name of the file, and you should be using either a String variable or a String literal of the filename.  E.g., "emergency_number.txt"
Here's an example I put together for you:
Anthony Holloway
Hi Anthony.
yes my mistake, i used the wrong file on upload stage.
i attached my modified script, but as soon as i entered the digits its just ring
can you please let me knoe how can i collect the digits and store it on the same file properly.
do i need to have two txt files on Document repository.
shameer
Because of script version dependency issues, could you please just post screenshots of the relevant parts?  I'm still in this with you though, so don't worry, we'll get it figured out.
Also, whenever I am trying to build a solution like this, I will create small individual scripts to vet specific solutions, and the script does not require an active contact (a phone call) to work.
Example:
If I were going to test reading the text file from the repository, I would screate a new script, and just have the two variables (String and Document) with the one step (Set my_string = my_document), and then use Active Debugging (Press F10) to test that out.  This way I don't have to save and upload, and refresh the application, followed by setting up a reactive debug, and then calling into the script.  It's too much overhead for testing simple solutions.
Anthony Holloway
Hi Anthony
Please see attached Script Image Screenshot
Thanks for the Testing tip as well.
shameer
Anthony Holloway
Hi Anthony
Full marks 10/10
After the change it worked.
Thank you so much for helping me to accomplish this script
Thank you once again for your great support
shameer
I'm glad you got your script working.  Until next time...
Anthony Holloway
