How to check the codec used for active call
fayiz husain
How can we check the codec used for active call?
Chris Deren
On 79XX phone you can simply double click the ? mark. On other phones you need to get to the phone details from menu.
You can also browse the IP address of the phone and see it on the active stream, or you are using you can check the GW via show active call commands.
HTH,
Chris
Chris Deren
HTH,
Chris
5 stars to Chris
chrysostomos
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
Thanks Chrysostomos, appreciate it, but where is the 5 stars
Chris
