01-13-2012 05:32 AM - edited 03-16-2019 08:59 AM
The Call Manager that I am using is version 6.1. Even though I had changed the URL Services Value to the current IP addess of the Call Manager, I am not able to access the Services on the Cisco IP Phone. When I press the Services button, it shows "Requesting" for a while and then finally displays "Host not found".
Gibin George.
01-13-2012 05:37 AM
Looking at a phone
Depending on model you should be able yo locate
the value of the services URL http://PUB IP ADDRESS:8080/ccmcip---------
Does this reflect your new IP address
Alex
01-14-2012 09:06 PM
Dear Alex,
The IP address is correct under the URL Services. The exact problem what I am facing is when I press the Services button I am able to select "Login Service" but soon after I press "Login Service", it shows "Requesting" for a while and finally displays "Host not found".
Gibin George
01-13-2012 05:39 AM
Take a look ont this doc
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080093e72.shtml
01-16-2012 02:12 AM
Can you look under:-
Device > Device Settings > Phone Services --> Find the EM service
Look at the URL-- You may need to change the IP address here
URL: http://
Save and Update Subscriptions
Alex
