IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5865 Views
  • 14 replies
Resolved! SIP, SCCP or SPCP
Hi,We are currently planning to implement 20 seat phone system for testing purposes and in next 12 - 18 months we will look to expand it to min 300 seats (we are IT department for pretty big (10 offices & 350 staff) company). We currently have C2921 ...
I just implemented "Mobile Connect" on our CUCM 8.5. (We use h.323 gateways, and PRI's.) It seems to be working correctly: if someone calls an internal line, it rings both the IP phone and the cell phone. I can answer it on the cell phone and it appe...
mstrz by Level 1
  • 1287 Views
  • 2 replies
Hi All,I has had problem to registering ATAS 187 on Cisco 7.1.3, and after looking on the Cisco Support Page I found that there is a QED File and Firmware for Version el CUCM Above 6.XJust look at this link.http://www.cisco.com/web/software/282074215...
Hello All,Looking for some help. I am working for the first time on setting up an eSRST/SRSV solution at our remote site. We are using:- UMG ver 8.6 (eSRST & SRSV)- Communications Manager Cluster is 7.1.3- Unity Connection 8.1- remotes are using ISR ...
Googi1974 by Level 1
  • 1398 Views
  • 1 replies
