03-19-2013 02:44 AM - edited 03-16-2019 04:19 PM
I have done the after-hour configuration with CME 8.8, phone number is blocked using after-hour config, but its not requesting a PIN to by pass the blocking, I have entered a PIN command under ephone also.
part of the config is bellow.
telephony-service
max-ephones 100
max-dn 100
ip source-address x.x.x.x port 2000
system message abc
time-zone 39
max-conferences 8 gain -6
web admin system name admin secret xxx
dn-webedit
time-webedit
transfer-system full-consult
login timeout 1 clear 23:00
after-hours block pattern 1 0777662756
after-hours day Sun 00:00 23:59
after-hours day Mon 00:00 23:59
after-hours day Tue 00:00 23:59
after-hours day Wed 00:00 23:59
after-hours day Thu 00:00 23:59
after-hours day Fri 00:00 23:59
after-hours day Sat 00:00 23:59
after-hours override-code 1234
after-hours login http
create cnf-files version-stamp 7960ccccc
ephone 14
device-security-mode none
mac-address 0023.049A.72B8
type 7911
button 1:14
pin 4321
Please help to resolve this issue.
Regds
03-19-2013 05:47 AM
Remove
from your configuration as this commands does the following:
Use this command to log in to a phone to unblock the after hour block and enable the phone user to place outgoing calls regardless of whether the outgoing called number matches the defined pattern of digits during the call blocking periods.
When you configure after-hours login http command, you will experience slightly different login behavior compare to the current one. This difference is because the after hours login mechanism is enhanced due to some UI limitation in the current model. By default, after-hours login http is not applied, which mean user will be using the existing after hours login mechanism.
By default, all IP phones in a Cisco Unified CME system are subject to call blocking if the Call Blocking feature is configured.
If you use an ephone template to apply a command to a phone and you also use the same command in ephone configuration mode for the same phone, the value that you set in ephone configuration mode has priority.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_a1ht.html#wp1130278
HTH,
Chris
