AIM CUE configuration not working.
johnhsnow
I have this configuration but it is not working. Should I be seeing the same ip address for both interfaces in show int brief (see below). I tried using loopback int on the service engine but it didnt work either. What am i missing here - cant session to CUE, cant ping module ip.
interface Loopback0
ip address 192.168.1.1 255.255.255.255
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.10
encapsulation dot1Q 10
ip address 192.168.10.1 255.255.255.0
interface GigabitEthernet0/0.20
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
interface GigabitEthernet0/0.100
encapsulation dot1Q 100
ip address 192.168.100.2 255.255.255.0
interface Service-Engine0/0
ip unnumbered GigabitEthernet0/0.20
service-module ip address 192.168.20.20 255.255.255.0
service-module ip default-gateway 192.168.20.1
Router#sh ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
GigabitEthernet0/0         unassigned      YES NVRAM  up                    up
GigabitEthernet0/0.10      192.168.10.1    YES NVRAM  up                    up
GigabitEthernet0/0.20      192.168.20.1    YES NVRAM  up                    up
GigabitEthernet0/0.100     192.168.100.2   YES NVRAM  up                    up
Service-Engine0/0          192.168.20.1    YES manual up                    down
GigabitEthernet0/1         unassigned      YES NVRAM  administratively down down
Loopback0                  192.168.1.1     YES NVRAM  up                    up
Router#  sh run int service-Engine 0/0
end
Router#sh run | s ip route
ip route 192.168.20.20 255.255.255.255 Service-Engine0/0
Router#sh ip route 192.168.20.20
Routing entry for 192.168.20.0/24
  Known via "connected", distance 0, metric 0 (connected, via interface)
  Routing Descriptor Blocks:
  * directly connected, via GigabitEthernet0/0.20
      Route metric is 0, traffic share count is 1
Router#ping 192.168.20.20
Sending 5, 100-byte ICMP Echos to 192.168.20.20, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Router#
johnhsnow
case closed: looks like module is DOA
Router#service-module service-Engine 0/0 status
Service Module is Cisco Service-Engine0/0
Service Module supports session via TTY line 194
Service Module is failed
Service Module heartbeat-reset is enabled
Service Module status is not available
Actually more likely is a CUE corrupted installation.
Hi Paolo
you mean a hardware or software installation? I didn't check the status of this module prior to configuring it.
