AIM-CUE Module Licensing.
angel-moon
Participant
Participant
                   Hello everyone,
thinking about picking up an AIM-CUE module off eBay for my lab.  Yes its an older piece but its all I can afford right now.  Can anyone tell me how licensing works on these units?  Do they come with 12 embedded or do you have to purchase a license to do anything?
Thanks in advance!  All replies rated.
anchoudh
Engager
Engager
Hi Angel-Moon,
Refer the "Table 8. License Support for Version 7.0 and Earlier"  in the below link,
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps5745/ps5520/product_data_sheet0900aecd806aefe4.html
Software Licenses and Factory-Set Limits
Factory-set system limits are determined by the license you have  purchased. Cisco Unity Express supports a maximum of 8 SIP triggers and 8  JTAPI triggers for all applications combined. This applies to NM-CUE,  NM-CUE-EC, NME-CUE, and the AIM-CUE modules.
System limits and license information for NM-CUE, NM-CUE-EC, NME-CUE,  and the AIM-CUE modules, and information about Interactive Voice  Response (IVR) licenses are in the Release Notes for Cisco Unity Express 7.0.
This product includes software developed by the OpenSSL Project for use in the OpenSSL Toolkit (http://www.openssl.org/).
Further information about the Cisco Unity Express Software Copyrights and Licenses is provided at: http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel2_3/licenses/lic_copy.html
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel7_0/install/over.html#wp1070899
Hope it helps.
Anand
anchoudh
Engager
Engager
Hi Angel-Moon,
Hope it helps.
Anand
Rob Huffman
Hall of Fame Community Legend Hall of Fame Community Legend
Hi Angel,
I just wanted to add a note to the great tips from Anand (+5 "A")
CUE pre-7.0 licenses are "honor" based;
Unity Express License Packages-3.2.5
Cheers!
Rob
"Why not help one another on the way" - Bob Marley
Recognize Your Peers
