Comcast is requiring the use of an RJ48C Crossover cable to connect to their PRI handoff. Has anyone seen any issues with using a standard PRI WIC card with that type of cable and service?
RJ48 is a standard PRI cable, if they require corssover you cannot use Ethernet cross over as different pairs are crosses, basically you need 1-4, 2-5 pin outs.
HTH,
Chris
