05-19-2008 03:13 PM - edited 03-15-2019 10:45 AM
I cannot install CUE 3.1.1 on my AIM module. What is the latest CUE version that supports AIM?
I would like to do AA scripts inside the CUE GUI like in 3.1.1.
Could I build a script in 3.1.1 and upload it to 2.3 and work?
Thanks in advance
05-19-2008 03:16 PM
I have upgraded many aim-cue to 3.1.2
What is yor exact problem ?
You need to create scripts with the same version of the editor as the CUE. Unfortunately that is a bit of a problem because apparently different versions of the editor cannot coexist in the same machine.
05-19-2008 04:02 PM
will 3.1.2 work with CME 4.2?
05-19-2008 04:08 PM
The CUE 3.1 Installation and Upgrade Guide states on page 27:
These procedures are available to systems with a network module........ CUE 3.1 does not support the 512 MB AIM-CUE.
I'm not sure they just don't mean the installation procedures....How do you install the 3.1.1 on an AIM module?
05-19-2008 11:28 PM
Hi, to be honest I didn't now looked at that, perhaps I have 1MB modules.
I just followed the upgrade procedures and it did go fine. And yes it works with CME 4.2
05-20-2008 12:33 AM
This is on a UC520 platform. Is the AIM module on CF? I thought AIMs were on motherboard. Is it possible to upgrade to 1GB AIM on the UC520?
I tried generating scripts in 3.1 GUI editor and transfer over to 2.3 but it didn't accept it.
I don't understand why they wouldn't interoperate. Aren't scripts generated in the CUE Script Editors the same? Can't these scripts be used across versions of CUE?
Thanks for helping
