Hi, Could any one help me out as how to configure the transcoding and MTP on AS 5400.
Hi,I've ccm at one location and pstn gw [mgcp] in another country. Delay between ccm and gw is almost 300ms. I've dsp resources which I want to use for conferencing [g.729 codec]. I know ccm uses sccp for hardwared based conferencing profile. I want...
I have a CME/CUE installation up and running without issues. I am however getting some customer feedback on how CUE addresses forwarded voice messages by default.When logged into voicemail and you forward a message, by default CUE asks you to spell ...
Voice packet was marked with DSCP EF, switch port was set to "trust dscp".As I known, most of Cisco switch and modules support only CoS maps to egress certain queue before sending out. My question is:if I only trust dscp at ingress port, the dscp val...
My question is if Cisco Catalyst switch can rewrite the CoS correctly between ISL and 802.1Q encapsulated packets.For example, packet with CoS 5 was encapsulated with 802.1Q and received by switch, if switch can write the same CoS value on the packet...
Hello,i have Main branch and 20 Branches, and i build a new network in the Main branch and other branches, so i want to build VOip solutions,,, so How can i start to build this sloution? also can i make integration between my PBX and the voip devices...
Hi,I have a MGCP gateway connecting to CCM 6.1 over a serial interface through a firewall. I configured MGCP bind media and control source interface to be loopback1. However, the firewall is seeing that the MGCP gateway is using the serial interface ...
Does a reload / reset of a CUE module involve rebooting the router ( 2851 )hosting it. And one more thing, do we need a separate backup nbefore reloading / rebooting the module. Think " copy run start" should suffice..
Hello,I have a system with CallManager 6.0, and Meeting Place Express 2.0. When I do normal calls through CallManager I have no problem with audio. However, when I get into a conference call using Meeting Place Express, I get good quality, but very l...
Please this is very urgent!!! I have an IPCC 4.0.5 server in my lab. I have a job to do for a customer tomorrow and need to simulate a few things. My IPCC server suddenly is not playing prompt or routing calls. when a call comes in it routes to the C...
I have a Unity install that was poorly designed. The Exchange message store and the Exchange Partner server are logically not very close to Unity. As a result users will occasionally get delays when checking messages over the phone. We are planning ...
I'm running a 2821 CME with CUE. Last night Unity started bouncing. I logged in got the "Session status is not available" Message.When I log into "service-module service-Engine 0/1 session"I can see the boot process which includes the error: (cat: wr...
Hello All...I'm trying to put together a line group for each one of our call centers as a backup plan in case IPCC fails. My question, can I use the 5-digit extensions that the call centers use when their agents are logged into IPCC? I know in the...
Hi all,i've configured MP 6.0 along with IP-GW, web conferenceing and GW-sim etc.. every thing is working fine .. i can dial-in via an ip phone and get the standard greeting.issue: in order to schedule a meeting or configure a web conference server, ...
Hi,I've got to the CCME html screen, typed in the IP address and username / password I use to log into my CCME but CUE wont accept my credentials, it gives the attatched message:I assume its looking for the credentials I use to log into CCME yes?
| Subject | Author | Posted |
| 03-25-2025 06:06 AM | ||
| 03-21-2025 01:42 PM | ||
| 03-20-2025 05:12 AM | ||
| 03-19-2025 06:53 AM | ||
| 03-18-2025 05:41 AM |
| User | Count |
| 5 | |
| 2 | |
| 2 | |
| 1 | |
| 1 |
