07-05-2018 04:00 AM - edited 03-17-2019 01:08 PM
Bit of a strange one... I am performing scheduled AD synchronization, however, the user accounts are by default set to not allow cross cluster EM login, see attached.
What I want to do is have the check box on the end user configuration to be ticked by default. I cant find a parameter that can be set to achieve this.
Any ideas?
Thanks in advance for any help!
Solved! Go to Solution.
07-05-2018 08:53 AM
I don't think there's a way to do what you're asking, none of the options to create automatically users and lines would do that. That checkbox only shows up after a user is associated to a UDP, and it's not a default option for users.
07-05-2018 04:35 AM
07-05-2018 06:21 AM
You'd need to mention what version you're using
If you mean modify your LDAP integration to modify existing users that will not work, if you make a change in a setting there, it will only be applied to new users that are synced.
07-05-2018 07:34 AM
Thanks to both for the reply!
I am using v11.5 - We have Cross-Cluster EM working, which is fine. What I want to do, is for the checkbox on the End-User page to be ticked by default to allow Cross-Cluster.
The reason I want to do this; I am integrating CUCM with a provisioning tool to pass new starter tasks to 1st line without the need for them to access CUCM Admin in order to create profiles, phones etc... this is one thing that is causing an issue - having to manually go in to end users and tick the box to allow.
Hopefully that all makes sense.
07-05-2018 08:53 AM
07-05-2018 09:13 AM
Thanks Jaime. Pity this cant be automated!
