Analog line call Issue
Bahlul Guliyev
Hello All,
When I call from analog line to PSTN, call is going out normally.
But after IVR telling me to dial extension number I can't dial.
Bahlul
20 Replies 20
Are you sure the phone upgraded the firmware to 9.4(1)?
Here's the 200 OK to the phone when the call is answered by IVR.
Aug  6 06:46:18.263: //1857/2DF031058BB2/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Aug  6 06:46:18.687: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:9195@11.11.11.1:5060 SIP/2.0
This is when the call is disconnected.
Aug  6 06:46:33.335: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:9195@11.11.11.1:5060 SIP/2.0
Via: SIP/2.0/UDP 11.11.11.49:5060;rport;branch=z9hG4bKPjGm5IPiXB-KDALUp8RiHMyGhIys0h1vEy
Max-Forwards: 70
From: "Mammadova Svetlana" <sip:3012@11.11.11.1>;tag=f6d651d6-848e-4716-953c-c6927083f389
To: sip:9@11.11.11.1;tag=DE91894-218B
Call-ID: 13684f3e-fa5e-4ab6-8939-880026b52655
CSeq: 12871 BYE
User-Agent: Cisco-CP3905/9.2.1
RTP-RxStat: Dur=15,Pkt=575,Oct=98728,LatePkt=0,LostPkt=0,AvgJit=2,VQMetrics="MLQK=3.1396;MLQKav=2.7148;MLQKmn=2.0000;MLQKmx=3.2783;MLQKvr=0.95;CCR=0.2269;ICR=0.0497;ICRmx=0.7383;CS=7;SCS=6"
RTP-TxStat: Dur=15,Pkt=279,Oct=12413
Content-Length:  0
We can see here that the User-agent is 3905 with 9.2.1. Can you check the firmware on the phone?
Also under voice register global, did you mention "load 3905 <9.4.1 loads file>"?
It was my fault. I deleted old firmware, and checked on the ip phone and on CME again, they showed me the new firmware file.
But the problem still exist
Ok can you try this under voice register pool,
no digit collect kpml
and make sure that dtmf-relay rtp-nte is configured on the voice register pool.
Hello Sreekanth
On my ip phone it shows new firmware but on my debugs it shows old firmware.
But I completely deleted old firmware and configuration of old firmware.
CME#sh voice register pool phone
Pool Device Name     Current-Version             Previous-Version
1    SEP6CFA89943C02 Cisco-CP3905/9.2.1
2    SEP6CFA89940490 Cisco-CP3905/9.2.1
3    SEP6CFA89940291 Cisco-CP3905/9.2.1
4    SEP6CFA89943AAE Cisco-CP3905/9.2.1
7    SEP6CFA89940936 Cisco-CP3905/9.2.1
8    SEP6CFA89940966 Cisco-CP3905/9.2.1
9    SEP6CFA89940965 Cisco-CP3905/9.2.1
10   SEP6CFA899409B8 Cisco-CP3905/9.2.1
11   SEP6CFA899404E0 Cisco-CP3905/9.2.1
12   SEP28C7CED74826 Cisco-CP3905/9.2.1
13   SEP28C7CED74723 Cisco-CP3905/9.2.1
14   SEP28C7CED748FB Cisco-CP3905/9.2.1
15   SEP28C7CED74838 Cisco-CP3905/9.2.1
16   SEP28C7CED70961 Cisco-CP3905/9.2.1
17   SEP28C7CED6BB64 Cisco-CP3905/9.2.1
That makes a huge difference. After reviewing your config a little closer it appears to be good. I thought I saw a different dial peer in your config for voip outgoing for some reason so I said it needed dtmp added, oops.
You can try to change the dtmf type to alphanumeric on the device before changing FW versions.
Please rate useful posts and mark answers as correct if applicable.
I don't think the 3905 will allow alphanumeric on it. It's a sip phone only.
We need ccsip messages and the rtp debugs to see if the phone negotiates any dtmf and if it sends any rtp-nte.
