Resolved! 9971 QoS question.
Hi, Shall we use " mls qos trust device cisco-phone " or " mls qos trust device cts "for 9971 phones as they support video calls ? Thanks,Khaled
Hi,Just thinking out loud, when you try to change description on gateway via BAT; does the import export method cos the gateway to get deleted and then get inserted? or does it just append only the new updates? How does BAT work.Do we have any Cisco ...
Hi there,I would like to know if I implement a 10 channel using a E1 ISDN service, what will be the interface number for the D channel. For example if I implement a full E1 ISDN, the D channel is normally on Serial0:0:15 Thanks Guys
I have a report in cucm that i have created where i can see the extention,device name and if it has a forward on , where it is forwarded. I have done this by going to bulk administration -> phone ->export phones -> specific details. I would to have ...
I am using cucm 8.6, configured a mgcp gateway and configured the fxo and fxs port(s).CLID presentation to the FXO port -> ip phones works perfectly, but the clid doesnt seem to get presented on the FXS port when debug on the gateway.Is this a know i...
Hi all,We have some trial DX650 units, and are trying to connect to our On premise WebEX & Also On premise Jabber IM servers.Both services fail to connect, we have tried multiple server settings, certificate options etc etc.The WebEx application says...
Hi Experts, I need to disable a single DSP on a 2811 router. C2811_CC#show voice dsp detailed DSP DSP DSPWARE CURR BOOT PAK TX/RXTYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABORT PACK COU...
Cisco Business Edition 6000 - Telepresence Room System User license when it required ,i am confused without this licenses i cannot able to register to CUCM? mean while i required telepresence room based endpoint single or multiscreen license?advice ...
Hello Folks, We have around 1200-1500 cisco 2821 series routers on those we are performing the hardware upgrade so we are taking the backup of all the files available in the flash of all the routers, we just want to know is there any trusted tool ava...
Hello fellow NetProsWe'll be starting a new Cisco IP Telephony project in Brazil next week. Since this is our first install for Brazil we have some doubts regarding the E1 trunks form the service provider. Aside from trying to get this information f...
Hi All Can CUCM 8.5 running on MCS7835I2 be upgraded to 10.5 on this platform? RegardsMarsha Laing
Hi, our client services team each has a separate call center extension. So they have one line for personal and one for call center. Users are now calling their 5 digit call center line instead of the HD number bypassing the call center all together...
Hi,Anybody knows which firmware/device pack do I need to download, in order to run a DX650 phone?CUCM version: 8.6.2
HI, I have an IP Telephony set up running on CUCM 9.1.Publisher and subscriber in a single site deployment model. Customized MOH were configured and running fine before.Now users are complaining that MOH is not working(both internal and external call...
Dear All,Here is the call flow for failed fax :ATA 187---------- CUCM 8.5 ----------2951 SIP CUBE------------ITSPWe have SIP link and a CUBE router, everything is working fine apart from the fax. Can someone please give me some sample config
Subject | Author | Posted |
08-18-2025 01:03 PM | ||
08-14-2025 06:35 AM | ||
07-23-2025 12:10 PM | ||
07-15-2025 06:51 AM | ||
07-09-2025 09:52 AM |
User | Count |
3 | |
3 | |
1 | |
1 | |
1 |
