08-04-2014 04:53 AM - edited 03-16-2019 11:37 PM
Hello All,
When I call from analog line to PSTN, call is going out normally.
But after IVR telling me to dial extension number I can't dial.
Bahlul
08-06-2014 04:44 AM
Are you sure the phone upgraded the firmware to 9.4(1)?
Here's the 200 OK to the phone when the call is answered by IVR.
Aug 6 06:46:18.263: //1857/2DF031058BB2/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 200 OK
Aug 6 06:46:18.687: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: ACK sip:9195@11.11.11.1:5060 SIP/2.0
This is when the call is disconnected.
Aug 6 06:46:33.335: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: BYE sip:9195@11.11.11.1:5060 SIP/2.0 Via: SIP/2.0/UDP 11.11.11.49:5060;rport;branch=z9hG4bKPjGm5IPiXB-KDALUp8RiHMyGhIys0h1vEy Max-Forwards: 70 From: "Mammadova Svetlana" <sip:3012@11.11.11.1>;tag=f6d651d6-848e-4716-953c-c6927083f389 To: sip:9@11.11.11.1;tag=DE91894-218B Call-ID: 13684f3e-fa5e-4ab6-8939-880026b52655 CSeq: 12871 BYE User-Agent: Cisco-CP3905/9.2.1 RTP-RxStat: Dur=15,Pkt=575,Oct=98728,LatePkt=0,LostPkt=0,AvgJit=2,VQMetrics="MLQK=3.1396;MLQKav=2.7148;MLQKmn=2.0000;MLQKmx=3.2783;MLQKvr=0.95;CCR=0.2269;ICR=0.0497;ICRmx=0.7383;CS=7;SCS=6" RTP-TxStat: Dur=15,Pkt=279,Oct=12413 Content-Length: 0
We can see here that the User-agent is 3905 with 9.2.1. Can you check the firmware on the phone?
Also under voice register global, did you mention "load 3905 <9.4.1 loads file>"?
08-06-2014 04:50 AM
It was my fault. I deleted old firmware, and checked on the ip phone and on CME again, they showed me the new firmware file.
But the problem still exist
08-06-2014 05:37 AM
Ok can you try this under voice register pool,
no digit collect kpml
and make sure that dtmf-relay rtp-nte is configured on the voice register pool.
08-07-2014 03:28 AM
Hello Sreekanth
On my ip phone it shows new firmware but on my debugs it shows old firmware.
But I completely deleted old firmware and configuration of old firmware.
CME#sh voice register pool phone
Pool Device Name Current-Version Previous-Version
1 SEP6CFA89943C02 Cisco-CP3905/9.2.1
2 SEP6CFA89940490 Cisco-CP3905/9.2.1
3 SEP6CFA89940291 Cisco-CP3905/9.2.1
4 SEP6CFA89943AAE Cisco-CP3905/9.2.1
7 SEP6CFA89940936 Cisco-CP3905/9.2.1
8 SEP6CFA89940966 Cisco-CP3905/9.2.1
9 SEP6CFA89940965 Cisco-CP3905/9.2.1
10 SEP6CFA899409B8 Cisco-CP3905/9.2.1
11 SEP6CFA899404E0 Cisco-CP3905/9.2.1
12 SEP28C7CED74826 Cisco-CP3905/9.2.1
13 SEP28C7CED74723 Cisco-CP3905/9.2.1
14 SEP28C7CED748FB Cisco-CP3905/9.2.1
15 SEP28C7CED74838 Cisco-CP3905/9.2.1
16 SEP28C7CED70961 Cisco-CP3905/9.2.1
17 SEP28C7CED6BB64 Cisco-CP3905/9.2.1
08-05-2014 04:59 AM
That makes a huge difference. After reviewing your config a little closer it appears to be good. I thought I saw a different dial peer in your config for voip outgoing for some reason so I said it needed dtmp added, oops.
You can try to change the dtmf type to alphanumeric on the device before changing FW versions.
08-05-2014 05:59 AM
I don't think the 3905 will allow alphanumeric on it. It's a sip phone only.
We need ccsip messages and the rtp debugs to see if the phone negotiates any dtmf and if it sends any rtp-nte.
