Analog phone volume is low on VG350
Lin Zhu
Hi all,  one customer complain that analog phone volume is pretty low, it connects to VG350,  can we increase it by CLI?
thanks.
R0g22
There are two things related to audio, output attenuation and input gain. OA is inversely proportional to the value your configure i.e. a negative value will increase the volume and a positive will decrease it. Input again is proportional, positive value means an increase and negative means a decrease. You will tweak OA if you want to +/- out audio, IG would be +/- in audio. Both values in decibels.
thanks Nipun,
I put IG to max value, but in-audio seems no any increase.
is there anything else I need to check?
voice-port 2/0/11
 input gain 14
 timeouts ringing infinity
