11-30-2020 10:37 AM
Why does Ans/Org appear to be in reverse on sh call active voice compact (and others)? I would expect the calling station who originated the call to show as "ORG" and not "ANS" as it shows in the command output below.
Total call-legs: 2
81438 ANS TO g729r8 VOIP P+14085557700 (calling station)
81439 ORG TO g711ulaw VOIP P816785555555 (called station)
Just curious if anyone knows why this is, or if I am misunderstanding the output? See image as well
Ryan
Solved! Go to Solution.
11-30-2020 09:10 PM - edited 12-01-2020 12:01 AM
Hey Hi ryandowdy
Total call-legs: 2
I assume you are having SIP TRUNKS on both sides of Router as the command output shows VOIP for both call legs.
Assume its CUBE, now think from CUBE perspective;
For 1st call leg, CUBE ANS the incoming call from CUCM to VOICE ROUTER. So treated as ANS to CALLING DEVICE +14085557700
For 2nd call leg, ORG TO (originated to) CALLED STATION 816785555555
This is how I understand... But other side I make sure the call is routed properly is what I always have concerns and also make sure the signaling path is correct from dial-peer voice in-out command output.
While testing from the above command #sh call activ voice compact, I make sure the correct calling and called party # is shown.
Hope that clarifies and helps...
Hey Hi ryandowdy
Total call-legs: 2
12-01-2020 07:20 AM
Thanks, Ritesh. Makes perfect sense if you look at it from the CUBE perspective.
