06-12-2013 04:49 PM - edited 03-16-2019 05:50 PM
Hi All,
I have an ISR cube with some SIP dial-peers and I have anti toll-fraud enabled using following configuration:
voice service voip
ip address trusted list
ipv4 x.x.x.x 255.255.255.255
ipv4 y.y.y.y 255.255.255.255
But I still keep getting stuff in the logs such as below.
I am wondering if anti toll-fraud is actually working since I see all that logs coming in.
Is this a supposed behaviour?
I see nothing from
debug voip ccapi inout though.
Here are the logs I get (I just removed the public IP address with zzz.zzz.zzz.zzz)
Can you please also help me read who is sending this traffic to me?
None of those IP addresses belong to my router.
*Jun 12 20:37:32.417: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:100@zzz.zzz.zzz.zzz SIP/2.0
Via: SIP/2.0/UDP 127.0.0.1:5082;branch=z9hG4bK-1815254791;rport
Content-Length: 0
From: "sipvicious"<sip:100@1.1.1.1>; tag=64393038323731303133633401363936343533373838
Accept: application/sdp
User-Agent: friendly-scanner
To: "sipvicious"<sip:100@1.1.1.1>
Contact: sip:100@127.0.0.1:5082
CSeq: 1 OPTIONS
Call-ID: 727754319672688427698085
Max-Forwards: 70
*Jun 12 20:37:32.418: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 400 Bad Request - 'Invalid IP Address'
Via: SIP/2.0/UDP 127.0.0.1:5082;branch=z9hG4bK-1815254791;rport;received=199.19.111.219
To: "sipvicious"<sip:100@1.1.1.1>;tag=55442526-1F8F
Date: Wed, 12 Jun 2013 20:37:32 GMT
Server: Cisco-SIPGateway/IOS-15.3.1.S2
CSeq: 1 OPTIONS
Content-Length: 0
06-12-2013 05:49 PM
Hi Ruter,
For what I can see, there's something called SIPVicious.
What is SIPVicious tool suite?
SIPVicious suite is a set of tools that can be used to audit SIP based VoIP systems.
Look like somebody is tryied to break the CUBE but it was block.
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
06-12-2013 05:54 PM
You're not getting ouptut on the Call Application Layer since the call is being rejected inmediately on the SIP Layer, hence the call is not being delivered to the next CUBE layer...
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
