anyone knows what means this alarm??
ciscoceci
Hi everyone,
We have received the follow alarm in our monitoring tool, anyone knows the reason??? i have revised the cisco real-time monitoring tool and i can not find anything...
regards
   500 Critical 22/05/13 10:00:13 17/05/13 9:55:23 xxxxx APP Telefonia xxxxx Error en ruta de sortida al RL_SBC, Reason=31, RouteGroups\(RG_TrunkSBC\)
9 Replies 9
ciscoceci
Sorry,
I forgot tell us that there are a SIP trunk for de incoming/outgoing calls
regards
Cause No. 31 - normal. unspecified.
This cause is used to report a normal event only when no other cause in the    normal class applies.
URL: https://supportforums.cisco.com/docs/DOC-29032
//Suresh Please rate all the useful posts.
many thanks sureshsub2,
Can i know the call rejected reason?
I have copy/paste logs where you can see the timestamp
regards
09:51:17.346 |GenAlarm: AlarmName = RouteListExhausted, subFac = CALLMANAGERKeyParam = , severity = 4, AlarmMsg = RouteListName : RL_SBC, Reason=31, RouteGroups(RG_TrunkSBC)
AppID : Cisco CallManager
ClusterID : StandAloneCluster
NodeID : xxxxx
09:51:17.346 |//SIP/SIPCdpc(2,74,31589)/ci=38852756/ccbId=255868/scbId=0/terminateOobDtmf: Termination not required.|2,100,63,1.320988^10.130.4.55^*
09:51:17.346 |//SIP/SIPD(2,73,1)/ccbId=255868/scbId=0/restart0_DStopInd: Removing Cdpc Pid (2,100,74,31589) with mapKey 0 from mCiToPid table|2,100,63,1.320988^10.130.4.55^*
09:51:17.346 |Cdcc::isStaticTransactionApplicable |2,100,63,1.320988^10.130.4.55^*
09:51:17.346 |cdrWrite PER RR, orig = 0, lrn = 0, current = 0|2,100,63,1.320988^10.130.4.55^*
09:51:17.346 |processCCMFeatureData: operationIeIdd=0|2,100,63,1.320988^10.130.4.55^*
09:51:17.346 |RouteListCdrc::routeListExhausted_shutting_down_DStopConf|2,100,63,1.320988^10.130.4.55^*
09:51:17.347 |!!ERROR!! -ConnectionManager- wait_AuDisconnectRequest :CI NOT FOUND IN TABLE,CI(38852755,38852756),discType=1,IFCreated(0,0),PID(0-0,0-0),IFHandling(0,0),MCNode(0,0)|2,100,63,1.320988^10.130.4.55^*
09:51:17.347 |EnvProcessCdr::wait_DbCdrReq|2,100,63,1.320988^10.130.4.55^*
09:51:17.347 |EnvProcessCdr::wait_DbCdrReq DETAILED Entries 47773, Inserts 47773,             ZeroCalls 0, StartRecords 0, Default 0|2,100,63,1.320988^10.130.4.55^*
      Have you checked the PRI/SIP Trunk utilisation?
the trunk is SIP and i have not check his utilisation. Do you think is a capacity problem in trunk???
regards
We used to get this error when all the channels are utilized. Just give a try and post the results.
do you face any issues with calls during this alarm? if so, please remove and readd the RG (RG_TrunkSBC) into RL (RL_SBC) and check if it makes any difference
The problemid is not present actually...
If i remove rg into rl it stop the call service
Existing calls will not be disturbed, calls progressing through the route list will be affected.
Sent from Cisco Technical Support Android App
