ASA 5506 [ASA Version 9.8(2)] open port 80 for one local Web_Server!
Imma
I have problem open port 80 on ASA firewall 5506 (routed mode). There are two WAN interfaces (VLAN192 for backup). Configuration as below:
object network Web-server-http
host 192.168.1.100
nat (inside,outside) static interface service tcp www www
object network web-server-VLAN192
nat (inside,VLAN192) static interface service tcp www www
access-list outside_access_in_1 extended permit tcp any object Web-server-http eq www
access-list VLAN192_access_in extended permit tcp any object Web-server-http eq www
access-group outside_access_in_1 in interface outside
access-group VLAN192_access_in in interface VLAN192
When I scan the public IP for open ports - port 80 status result -Filtered. What I am missing?
I have followed the below guide:
https://www.petenetlive.com/KB/Article/0000077
Thank you in advanced,
Denisa
Hi Balaji,
Thank you for your reply.
The guide you suggested did not work. It was the same with the guide I first followed.
In the attached file I have described the solution.
1. Create Access-List. Destination-Private IP of the Server. Service port http
2. Create NAT Rule: Add NAT Rule before: “Network Object” NAT Rules
3. Service Port must be created – Source Port
Kind Regards,
Denisa
balaji.bandi
Some time Scanning will detect ASA side as Attack, depends on how you scan.
how about you try telnet public-ip 80 (are you able to connect ?)
here is the clear setup guide
https://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/118996-config-asa-00.html
BB
Hi Balaji,
Kind Regards,
Denisa
