08-15-2012 04:59 AM - edited 03-16-2019 12:43 PM
Hi!
My end costumer want to separate their BRI depending from what extension is going to place the call, they want BRI 0/0/0 and 0/0/1 be assigned to extension 4101 and 4102, and the rest of the enterprise the remaining BRI, (the remaining 6).
I think this will be into dial-peer, any idea to make this issue?
Thanks!!
Solved! Go to Solution.
08-15-2012 05:03 AM
This is often asked, have you tried searching "mapping unique ports to extensions".
08-15-2012 05:03 AM
08-17-2012 04:22 AM
Hi!
Thanks, i added into the dial-peer 9T and others with 0T, so this resolve my problem
Regards!!
