05-30-2012 11:17 PM - edited 03-16-2019 11:25 AM
Dear All,
Here is the call flow for failed fax :
ATA 187---------- CUCM 8.5 ----------3925 SIP Gateway------------ Huawei softx3000 SIP provider
FAX mode is ATA is Fax pass through.
Fax is failing with strange RTP payload Type Behaviour.
RTP pt vary from 97 ,101 ,127 etc.
attached debug file.
Solved! Go to Solution.
06-04-2012 03:20 AM
Dear Aokanlawon,
1.fax machine is connected to ATA 187.
2.Analog phone can make call connected to ATA 187.
3.SIP Gateway is CUBE.
4.ATA configured for fax-passthrough.
5.ATA 187 is having firmware 9.2.3
I have done following :
1.ATA fax mode is fax-passthrough.
2.done
3.done
4.region is defined in call manager as: can not change the codec.
region max audio max video
REG-AQSHO 64kbps (g.722 ,g.711) 384
5.ATA is having latest 9.2.3.
6.on the sip dial-peer codec is configured as g711alaw.telephone call is going. with this
if i change it to g711ulaw then call is not going.
7. vtsp debug is for port.
i will send debug once remote guy will be available for fax testing.
Thank you
06-04-2012 03:25 AM
Can you send updated gateway config? IS region-aqsho assigned to gateway and ATA?
Please rate useful posts
06-04-2012 05:24 AM
06-04-2012 05:31 AM
I said you should remove "fax protocol pass-through g711ulaw" from all your dial-peers
configure
voice service voip
no fax protocol pass-through g711ulaw
fax protocol none
I still see this in your configs...
Please remove and try again
