ATA 187 - Lpcor support
Jose Arango
Hi Everybody,
I have a CME with Lpcor enabled, I connected an ATA187 with two lines configured , when I enable the lpcor feature  under the voice register pool, it does not work (lpcor incoming XXXXX). Is the LPCOR feature supported for these kind of devices?
Jose
Rob Huffman
Hi Jose,
Should be supported. Have a look at the attached doc
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmelpcor.html#wp1059981
Cheers!
Rob
"What you don't have you don't need it now"
- U2
