Hello Everyone,
I have an anooy problem with ATA 187 on CME 9.0
I preconfigure everything back in the office, at that time ATA 187 work fine with CME - "show voice register pool type ata-187" show that both number were registered to CME. But for some reason after the device was send to the customer site, it always register with first port(second port show unregister).
I try every solution I could think of, restart and reset the "voice register pool", delete and reconfigure dn and pool, no create profile and create profile, ect..
But None of the solution above work. Here is my configuration.
voice register dn 98
number 5598
voice register dn 99
number 5599
voice register pool 1
id mac xxxx.xxxx.xxxx
codec g711ulaw
number 1 dn 98
number 2 dn 99
Pichan
The ATA 187 follows the same MAC address rules as the ATA 186 & 188
If the ATA 187 has an original MAC address :-
AAAA.BBBB.CCCC this is used for the 1st port
The 2nd port uses the following address
AABB.BBCC.CC01
So the rule is delete the first 2 numbers on the left and add 01 at the end
Another example would be:-
1st port 2222.3333.4444
2nd port 2233.3344.4401
In your config you need to register another MAC
id mac xxxx.xxxx.xx01
codec g711ulaw
number 1 dn 100
number 2 dn 101
Hope this helps
Alex.
Please rate useful posts.
