ATA 190 Web Interface ID & Password
Gordon Ross
Level 9
Level 9
What's the default ID & Password for the ATA190 Web interface? I can't find it in the manual ( http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/cata/190/1_0/english/administration/guide/sip/ATA190_AG.pdf )
GTG
Please rate all helpful posts.
7 Replies 7
MaxBoeglich
User:
UID: cisco
PW: cisco
Admin:
UID:admin
PW:admin
With that Admin login, can we change setting?
I saw "submit" button on each page, but not allow to change any.
Also, grayed out radio button.
Please advise.
There are multiple bugs in the early versions of ATA190 firmware (Including this one). Make sure you install the latest version.
GTG
Thank you for the comments.
Do you know the way to upgrade ATA190 thru CUCME?
I found a way with CUCM, but not CUCME.
Currently, we are replacing ATA186 with ATA190.
Seems like setting will be a lot different from ATA186(IOS gateway setting, SIP proxy).
Chris
Sorry, but I don't know CUCME, so can't help you on this. (If you don't get an answer here, maybe start a fresh discussion so people pick it up.)
GTG
Thank you so much again.
Chris
Username: admin
Password: Admin246810
