ATA 191, Can't configure second line
eldangab
Hi, I have an ATA 191 box, and I'm trying to configure two lines.
When I configure the 2nd line, it appears under the "Unassigned Associated Items" section.
When I try to reorder the phone button configuration, I get an error: "Fixed feature buttons cannot be changed."
And if I try to choose a different button template, I can't select anything except the default ATA 191.
Any ideas?
b.winter
You cannot configure the 2nd port that way. Have a look at this example post: https://community.cisco.com/t5/ip-telephony-and-phones/configure-second-line-in-ata-187/td-p/2472948
There are a lot of other posts if you search the forum.
