ATA 191 SIP firmware upgrade
osman.nayeem
Hi experts
Would you please help me with the answer of following questions?
1-Is it possible to upgrade firmware of ATA 191 SIP from call manager (version 11.5) like IP phone firmware upgrade? Or we have to do it manually? We want to upgrade firmware from 12.01 to 12.01 SR1.
2-Could you please help with the upgrade process if manually upgrading is the only option for ATA 191?
Thank you!
Brandon Buffin
You can upgrade firmware from CUCM like any other phone. Download the latest release and install on all CUCM servers.
Brandon
I was having this issue as well.  After uploading the firmware to CUCM and restarting the necessary services. It can take 25 minutes from the time the ATA191 starts the upgrade until it finally reboots with the new firmware.
If you watch the logs on the ATA191 you will see the following when it starts the upgrade process:
Jan 1 00:00:56 ATA191 Telephony: [prov_handle_firmware_upgrade: 1783(tick=0x0)]CURRENT SW_VRSION - ATA191.12-0-1-29
Jan 1 00:00:56 ATA191 Telephony: [prov_handle_firmware_upgrade: 1784(tick=0x0)]TARGET SW_VRSION - ATA191.12-0-1SR2-3
Jan 1 00:00:56 ATA191 Telephony: [prov_handle_firmware_upgrade: 1805(tick=0x0)]nfw=ATA191.12-0-1SR2-3, bfw=
Jan 1 00:00:56 ATA191 Telephony: [prov_handle_firmware_upgrade: 1817(tick=0x0)]prov_handle_firmware_upgrade 1817 loads_fname:ATA191.12-0-1SR2-3.loads
Jan 1 00:00:56 ATA191 Telephony: [prov_tftp_download: 756(tick=0x0)]download [ATA191.12-0-1SR2-3.loads] data len=364
Jan 1 00:00:56 ATA191 Telephony: [prov_tftp_download: 766(tick=0x0)]download [ATA191.12-0-1SR2-3.loads] OK!
Jan 1 00:00:56 ATA191 Telephony: [prov_tftp_download_file: 822(tick=0x0)]file_len = 364, data_len = 364
Jan 1 00:00:56 ATA191 Telephony: [auth_image_file: 698(tick=0x0)]bfe auth, filepath=/tmp/ATA191.12-0-1SR2-3.loads
Jan 1 00:00:56 ATA191 Telephony: [auth_image_file: 699(tick=0x0)]bfe auth
Jan 1 00:00:56 ATA191 : IMGAUTH_FILExx hit11: filename:/tmp/ATA191.12-0-1SR2-3.loads, name:ATA191.12-0-1SR2-3.loads, headerSize:1290245120
Those lines will repeat every few minutes.
You will also see the MemFree will continue to drop:
Jan 1 00:05:11 ATA191 System[677]: MemFree: 92340 kB
Jan 1 00:10:13 ATA191 System[677]: MemFree: 86184 kB
Jan 1 00:15:14 ATA191 System[677]: MemFree: 79912 kB
Jan 1 00:20:15 ATA191 System[677]: MemFree: 73584 kB
Eventually it will log when it finally upgrades:
<27>Jan 1 00:24:24 ATA191 System[1169]: Upgrade Successfully.
<28>Jan 1 00:24:25 ATA191 CDPLLDP: [lldpproto_send_pdu][1264] lldp send packet
<142>Jan 1 00:24:26 ATA191 Telephony: [prov_upgrade_firmware: 1658(tick=0x0)][Auto upgrade] Upgrader result: OK
<142>Jan 1 00:24:26 ATA191 Telephony: [prov_upgrade_firmware: 1661(tick=0x0)]UPG: upgrade done, rebooting
<13>Jan 1 00:24:26 ATA191 shutdown[1191]: shutting down for system reboot
I hope this helps anyone else who may run across this in the future.
DanKirk025697
I am trying to firmware upgrade "ATA191.12-0-1-0301-002" via tftp. Do you have a copy of XML format(XML) profile?
Thank you,
Lee
