ATA and faxes issue
shiblyibrahim
Level 3
Level 3
I configured an ATA. Its a CME based system. CME version 8.6
I tested inbound and outbound faxes and it did work. But customer complained that some of their suppliers are having issues sending faxes to them.
I tested once the fax went through and another time it failed. It seems quite intermittent.
Any suggestion would be appreciated. Please find the config below
ephone 45
device-security-mode none
mac-address 000C.3052.8E3B
ephone-template 1
max-calls-per-button 2
type ata
button 1:55
ephone-dn 55 dual-line
number 8099
dial-peer voice 50 voip
destination-pattern 8099
modem passthrough nse codec g711ulaw
session target ipv4:192.168.150.58
codec g711ulaw
fax rate disable
no vad
voice service pots
fax rate disable
voice service voip
Please rate the post Shibly Ibrahim
Pls Try the below and return back wiith a feedback
voice service voip
fax protocol pass-through g711alaw or ulaw
modem passthrough nse codec g711alaw ------->or ulaw
codec g711alaw   ------------->or ulaw
fax-relay ecm disable
no fax-relay sg3-to-g3
dtmf-relay h245-alphanumeric
fax rate 9600
fax protocol pass-through g711alaw -------->or ulaw
no vad
chrysostomos
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
Hey Chrys,
Thanks. I was making the changes and in the meantime I had a tac case logged with cisco. She said I wouldnt need the dial-peer at all since the analog device would be a device part of the system and therefore the dial-peer is not necessary.
I have removed it and tested twice waiting for customer to get back to me on this.
Chris by the way thanks for the help. If this doesnt work I am going to use your solution and see.
You are very welcome
Pls return back when the problem solved to update the case
Will help  other people with the same issue
