08-07-2016 03:16 AM - edited 03-17-2019 07:45 AM
Dear all,
I am having a call manager 8.5 and a gateway
I configured an ATA 186 in
Fax machine is sending the faxes but we are facing an issue in incoming
what configurations should be made in ATA and also in
Can anyone guide?
08-07-2016 07:06 AM
How are you integrating PSTN with CUCM (protocols and analog port type)?
Also, share your gateway config.
08-07-2016 04:36 PM
in terms of dial plan, there is no difference between any regular phone and a fax, so if you can call a phone from external, the fax should be 'callable' as well. If you are not sure, hook up an analogue phone to the ATA and ring into it.
08-07-2016 11:07 PM
I am able to send fax to any number without any issue
but the problem is for receiving the fax
no need of configuration in ATA? or if, then what should I keep
when I look into the document it say some configuration is needed in ATA
Audio mode, connect mode ...
