SIP Trunk Error 503
drbabbers
Level 3
Level 3
All,
Ive setup a fairly SIP Trunk between 2 CUCM clusters and I when I attempt to send calls across it I am getting a Error 503 on the SIP Trunk.
Basic IP connectivity tests have been done and everything looks OK.
Any ideas what I should do next please?
D
Vivek Batra
Can you please share the SIP call trace from INVITE to 503?
- Vivek
Manish Gogna
You will need to check the config of SIP trunks on both clusters and also the Route patterns. Please ensure that the destination IP addresses are correct and the CSS for Incoming calls settings on SIP trunk has access to the DN that is being called on that cluster. If possible share the screenshot of the Route pattern and SIP trunks from both sides.
Manish
- Do rate helpful posts -
dsutphin
Do not want to highjack this feed but i am experiencing a similar issue if not the same thing.
CUCM (6.x) sip trunk (CUCM 11)
call flow
CUCM
RP 1120
GW ICT_TO_NEW_SYSTEM
PT=PT_Internal
SIP TRUNK
DP=DP_HQ
Destination address 10.1.2.20 (CUCM 11)
rerouting CSS=CSS_HQ_Local
CSS=CSS_Local
********* send call across SIP Trunk
DP=DP_HQ
CSS=CSS_HQ-Local
Destination address 10.1.2.10 (CUCM 6)
translation pattern
1120 xlate t0 3000 (vm hunt Pilot)
PT=PT_Internal
CSS=CSS_HQ_Local
outcome -- Busy Signal received when calling 1120 from CUCM 6.
when dial 1120 on CUCM 11 call makes it to CUC.
Pings good both ways.
Dennis Sutphin Jr.
Can you add some SIP traces to this post, I d like to see what your calling CUCM is sending.  As its obviously sending something your receiving CUCM doesn't like.
Please remember to rate useful posts, by clicking on the stars below.
