ATA187 status is Registering.
kmohdsabu
Hi Techizzzz,
ATA 187 is not registering. Please find below the log.
2000/01/28 09:35:39:455   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:36:14:185   TFTP Timeout : CTLSEPB8BEBF9D430D.tlv
2000/01/28 09:36:14:189   No CTL installed
2000/01/28 09:36:14:192   IP phone is in non-secure mode
2000/01/28 09:36:38:584   TFTP Timeout : ATAB8BEBF9D430D.cnf.xml
2000/01/28 09:36:56:855   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:37:10:174   TFTP Timeout : CTLSEPBEBF9D430D01.tlv
2000/01/28 09:37:10:178   No CTL installed
2000/01/28 09:37:10:182   IP phone is in non-secure mode
2000/01/28 09:37:34:574   TFTP Timeout : ATABEBF9D430D01.cnf.xml
2000/01/28 09:37:52:834   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:38:27:524   TFTP Timeout : CTLSEPB8BEBF9D430D.tlv
2000/01/28 09:38:27:529   No CTL installed
2000/01/28 09:38:27:532   IP phone is in non-secure mode
2000/01/28 09:38:51:925   TFTP Timeout : ATAB8BEBF9D430D.cnf.xml
2000/01/28 09:39:10:195   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:39:23:514   TFTP Timeout : CTLSEPBEBF9D430D01.tlv
2000/01/28 09:39:23:519   No CTL installed
2000/01/28 09:39:23:522   IP phone is in non-secure mode
2000/01/28 09:39:47:934   TFTP Timeout : ATABEBF9D430D01.cnf.xml
2000/01/28 09:40:06:193   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:40:40:875   TFTP Timeout : CTLSEPB8BEBF9D430D.tlv
2000/01/28 09:40:40:879   No CTL installed
2000/01/28 09:40:40:883   IP phone is in non-secure mode
2000/01/28 09:41:05:285   TFTP Timeout : ATAB8BEBF9D430D.cnf.xml
2000/01/28 09:41:23:555   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:41:36:874   TFTP Timeout : CTLSEPBEBF9D430D01.tlv
2000/01/28 09:41:36:878   No CTL installed
2000/01/28 09:41:36:882   IP phone is in non-secure mode
2000/01/28 09:42:01:293   TFTP Timeout : ATABEBF9D430D01.cnf.xml
2000/01/28 09:42:19:544   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:42:54:235   TFTP Timeout : CTLSEPB8BEBF9D430D.tlv
2000/01/28 09:42:54:240   No CTL installed
2000/01/28 09:42:54:243   IP phone is in non-secure mode
2000/01/28 09:43:18:636   TFTP Timeout : ATAB8BEBF9D430D.cnf.xml
2000/01/28 09:43:36:896   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:43:50:214   TFTP Timeout : CTLSEPBEBF9D430D01.tlv
2000/01/28 09:43:50:218   No CTL installed
2000/01/28 09:43:50:222   IP phone is in non-secure mode
2000/01/28 09:44:14:605   TFTP Timeout : ATABEBF9D430D01.cnf.xml
2000/01/28 09:44:32:844   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:45:07:535   TFTP Timeout : CTLSEPB8BEBF9D430D.tlv
2000/01/28 09:45:07:540   No CTL installed
2000/01/28 09:45:07:543   IP phone is in non-secure mode
2000/01/28 09:45:31:935   TFTP Timeout : ATAB8BEBF9D430D.cnf.xml
2000/01/28 09:45:50:195   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:46:03:514   TFTP Timeout : CTLSEPBEBF9D430D01.tlv
2000/01/28 09:46:03:518   No CTL installed
2000/01/28 09:46:03:522   IP phone is in non-secure mode
2000/01/28 09:46:27:934   TFTP Timeout : ATABEBF9D430D01.cnf.xml
2000/01/28 09:46:46:194   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:47:20:893   TFTP Timeout : CTLSEPB8BEBF9D430D.tlv
2000/01/28 09:47:20:898   No CTL installed
2000/01/28 09:47:20:902   IP phone is in non-secure mode
2000/01/28 09:47:45:305   TFTP Timeout : ATAB8BEBF9D430D.cnf.xml
2000/01/28 09:48:03:574   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:48:16:885   TFTP Timeout : CTLSEPBEBF9D430D01.tlv
2000/01/28 09:48:16:889   No CTL installed
2000/01/28 09:48:16:892   IP phone is in non-secure mode
2000/01/28 09:48:41:294   TFTP Timeout : ATABEBF9D430D01.cnf.xml
2000/01/28 09:48:59:544   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:49:34:255   TFTP Timeout : CTLSEPB8BEBF9D430D.tlv
2000/01/28 09:49:34:260   No CTL installed
2000/01/28 09:49:34:263   IP phone is in non-secure mode
2000/01/28 09:49:58:674   TFTP Timeout : ATAB8BEBF9D430D.cnf.xml
2000/01/28 09:50:16:935   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:50:30:254   TFTP Timeout : CTLSEPBEBF9D430D01.tlv
2000/01/28 09:50:30:259   No CTL installed
2000/01/28 09:50:30:263   IP phone is in non-secure mode
2000/01/28 09:50:54:656   TFTP Timeout : ATABEBF9D430D01.cnf.xml
2000/01/28 09:51:12:903   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:51:47:614   TFTP Timeout : CTLSEPB8BEBF9D430D.tlv
2000/01/28 09:51:47:619   No CTL installed
2000/01/28 09:51:47:622   IP phone is in non-secure mode
2000/01/28 09:52:12:014   TFTP Timeout : ATAB8BEBF9D430D.cnf.xml
2000/01/28 09:52:30:276   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:52:43:595   TFTP Timeout : CTLSEPBEBF9D430D01.tlv
2000/01/28 09:52:43:599   No CTL installed
2000/01/28 09:52:43:603   IP phone is in non-secure mode
2000/01/28 09:53:08:014   TFTP Timeout : ATABEBF9D430D01.cnf.xml
2000/01/28 09:53:26:264   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:54:00:975   TFTP Timeout : CTLSEPB8BEBF9D430D.tlv
2000/01/28 09:54:00:979   No CTL installed
2000/01/28 09:54:00:983   IP phone is in non-secure mode
2000/01/28 09:54:25:384   TFTP Timeout : ATAB8BEBF9D430D.cnf.xml
25 Replies 25
Sreekanth Narayanan
Where are you trying to register the ATA 187 to? CUCM or CME?
We can see that there is a tftp timeout when it's trying to register.
Sreekanth
Thanks for the replay.
I am try to register the CUCM 8.5.1.14068-1. The ATA 187 was registered in callmanger. Suddenly it is unregistered.
This could be a network issue. What is the topology between the ata 187 and the CUCM?
The ATA 187 is sip so if one of the REGISTER messages did not receive a 200 OK from the call manager, or if the register keepalive did not make it to the call manager, the device will be marked as unregistered.
Check to see if any changes were made on the network if this device was registered before.
Brian Meade
Level 7
Level 7
It looks like the device is failing to pull its config via TFTP.  Check the web page to see if it has the correct TFTP server configured first.
Yes TFTP is correct.
Try pulling down the config file (ATABEBF9D430D01.cnf.xml) using a TFTP client connected to that TFTP server. You might just need to restart the TFTP service.
Please provide me the step, how to do this.
Thanks.
Are using asking for instructions on how to use a TFTP Client?
Windows has one built-in but may not be enabled on your PC.
I would suggest using google to learn how to use a TFTP client of your choice.
how to pulling down the config file (ATABEBF9D430D01.cnf.xml) using a TFTP client?
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/tftp.mspx?mfr=true
Thanks in advance.
I have pulled down the config file (ATABEBF9D430D01.cnf.xml) using a TFTP client. but ATA still same registering.
Can you upload that file on here?  Can you also upload the console logs from the ATA's web page?
Thanks in advance.
here is the log.
here is config file.
