ATA187 status is Registering.
kmohdsabu
Hi Techizzzz,
ATA 187 is not registering. Please find below the log.
2000/01/28 09:35:39:455   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:36:14:185   TFTP Timeout : CTLSEPB8BEBF9D430D.tlv
2000/01/28 09:36:14:189   No CTL installed
2000/01/28 09:36:14:192   IP phone is in non-secure mode
2000/01/28 09:36:38:584   TFTP Timeout : ATAB8BEBF9D430D.cnf.xml
2000/01/28 09:36:56:855   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:37:10:174   TFTP Timeout : CTLSEPBEBF9D430D01.tlv
2000/01/28 09:37:10:178   No CTL installed
2000/01/28 09:37:10:182   IP phone is in non-secure mode
2000/01/28 09:37:34:574   TFTP Timeout : ATABEBF9D430D01.cnf.xml
2000/01/28 09:37:52:834   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:38:27:524   TFTP Timeout : CTLSEPB8BEBF9D430D.tlv
2000/01/28 09:38:27:529   No CTL installed
2000/01/28 09:38:27:532   IP phone is in non-secure mode
2000/01/28 09:38:51:925   TFTP Timeout : ATAB8BEBF9D430D.cnf.xml
2000/01/28 09:39:10:195   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:39:23:514   TFTP Timeout : CTLSEPBEBF9D430D01.tlv
2000/01/28 09:39:23:519   No CTL installed
2000/01/28 09:39:23:522   IP phone is in non-secure mode
2000/01/28 09:39:47:934   TFTP Timeout : ATABEBF9D430D01.cnf.xml
2000/01/28 09:40:06:193   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:40:40:875   TFTP Timeout : CTLSEPB8BEBF9D430D.tlv
2000/01/28 09:40:40:879   No CTL installed
2000/01/28 09:40:40:883   IP phone is in non-secure mode
2000/01/28 09:41:05:285   TFTP Timeout : ATAB8BEBF9D430D.cnf.xml
2000/01/28 09:41:23:555   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:41:36:874   TFTP Timeout : CTLSEPBEBF9D430D01.tlv
2000/01/28 09:41:36:878   No CTL installed
2000/01/28 09:41:36:882   IP phone is in non-secure mode
2000/01/28 09:42:01:293   TFTP Timeout : ATABEBF9D430D01.cnf.xml
2000/01/28 09:42:19:544   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:42:54:235   TFTP Timeout : CTLSEPB8BEBF9D430D.tlv
2000/01/28 09:42:54:240   No CTL installed
2000/01/28 09:42:54:243   IP phone is in non-secure mode
2000/01/28 09:43:18:636   TFTP Timeout : ATAB8BEBF9D430D.cnf.xml
2000/01/28 09:43:36:896   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:43:50:214   TFTP Timeout : CTLSEPBEBF9D430D01.tlv
2000/01/28 09:43:50:218   No CTL installed
2000/01/28 09:43:50:222   IP phone is in non-secure mode
2000/01/28 09:44:14:605   TFTP Timeout : ATABEBF9D430D01.cnf.xml
2000/01/28 09:44:32:844   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:45:07:535   TFTP Timeout : CTLSEPB8BEBF9D430D.tlv
2000/01/28 09:45:07:540   No CTL installed
2000/01/28 09:45:07:543   IP phone is in non-secure mode
2000/01/28 09:45:31:935   TFTP Timeout : ATAB8BEBF9D430D.cnf.xml
2000/01/28 09:45:50:195   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:46:03:514   TFTP Timeout : CTLSEPBEBF9D430D01.tlv
2000/01/28 09:46:03:518   No CTL installed
2000/01/28 09:46:03:522   IP phone is in non-secure mode
2000/01/28 09:46:27:934   TFTP Timeout : ATABEBF9D430D01.cnf.xml
2000/01/28 09:46:46:194   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:47:20:893   TFTP Timeout : CTLSEPB8BEBF9D430D.tlv
2000/01/28 09:47:20:898   No CTL installed
2000/01/28 09:47:20:902   IP phone is in non-secure mode
2000/01/28 09:47:45:305   TFTP Timeout : ATAB8BEBF9D430D.cnf.xml
2000/01/28 09:48:03:574   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:48:16:885   TFTP Timeout : CTLSEPBEBF9D430D01.tlv
2000/01/28 09:48:16:889   No CTL installed
2000/01/28 09:48:16:892   IP phone is in non-secure mode
2000/01/28 09:48:41:294   TFTP Timeout : ATABEBF9D430D01.cnf.xml
2000/01/28 09:48:59:544   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:49:34:255   TFTP Timeout : CTLSEPB8BEBF9D430D.tlv
2000/01/28 09:49:34:260   No CTL installed
2000/01/28 09:49:34:263   IP phone is in non-secure mode
2000/01/28 09:49:58:674   TFTP Timeout : ATAB8BEBF9D430D.cnf.xml
2000/01/28 09:50:16:935   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:50:30:254   TFTP Timeout : CTLSEPBEBF9D430D01.tlv
2000/01/28 09:50:30:259   No CTL installed
2000/01/28 09:50:30:263   IP phone is in non-secure mode
2000/01/28 09:50:54:656   TFTP Timeout : ATABEBF9D430D01.cnf.xml
2000/01/28 09:51:12:903   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:51:47:614   TFTP Timeout : CTLSEPB8BEBF9D430D.tlv
2000/01/28 09:51:47:619   No CTL installed
2000/01/28 09:51:47:622   IP phone is in non-secure mode
2000/01/28 09:52:12:014   TFTP Timeout : ATAB8BEBF9D430D.cnf.xml
2000/01/28 09:52:30:276   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:52:43:595   TFTP Timeout : CTLSEPBEBF9D430D01.tlv
2000/01/28 09:52:43:599   No CTL installed
2000/01/28 09:52:43:603   IP phone is in non-secure mode
2000/01/28 09:53:08:014   TFTP Timeout : ATABEBF9D430D01.cnf.xml
2000/01/28 09:53:26:264   TFTP Timeout : tzdatacsv.csv
2000/01/28 09:54:00:975   TFTP Timeout : CTLSEPB8BEBF9D430D.tlv
2000/01/28 09:54:00:979   No CTL installed
2000/01/28 09:54:00:983   IP phone is in non-secure mode
2000/01/28 09:54:25:384   TFTP Timeout : ATAB8BEBF9D430D.cnf.xml
25 Replies 25
It's failing to download the config file via TFTP:
2000/01/01 00:11:10:515 1 TFTP Timeout : ATABEBF9DBB1F01.cnf.xml
00:11:12:523 w [SUU] [tftp] Command = tftp -g -r "ATABEBF9DBB1F01.cnf.xml" 168.189.29.5 69 -l /var/prov/ATABEBF9DBB1F01.cnf.xml -t 6 -s 524288 -q 96
Is it possible something is blocking TFTP (UDP port 69) on the subnet the ATA is on?
Thanks in advance.
How to fix this issue?
Contact your network engineer.
Can you explain..what is reason for failing to download the config file via TFTP?
It looks like the network is blocking the TFTP traffic.  We can conclude that since you can download the same file successfully via a PC running a TFTP client pointed to the same TFTP server.
24hrschat
I am trying to register ATA187 to CUCM 8.6.2 but no luck. In call manager status showing REJECTED.
Following is the status message from the web page
2000/01/01 00:00:45:194   File Not Found : CTLSEPD824BDBB0FA0.tlv
2000/01/01 00:00:45:199   No CTL installed
2000/01/01 00:00:45:202   IP phone is in non-secure mode
2000/01/01 00:00:46:126   Succeed to get ATAD824BDBB0FA0.cnf.xml
2000/01/01 00:00:45:375   File Not Found : CTLSEPD824BDBB0FA0.tlv
2000/01/01 00:00:45:379   No CTL installed
2000/01/01 00:00:45:383   IP phone is in non-secure mode
2000/01/01 00:00:46:326   Succeed to get ATAD824BDBB0FA0.cnf.xml
2000/01/01 00:00:45:475   File Not Found : CTLSEPD824BDBB0FA0.tlv
2000/01/01 00:00:45:479   No CTL installed
2000/01/01 00:00:45:483   IP phone is in non-secure mode
2000/01/01 00:00:46:437   Succeed to get ATAD824BDBB0FA0.cnf.xml
2000/01/01 00:00:45:394   File Not Found : CTLSEPD824BDBB0FA0.tlv
2000/01/01 00:00:45:399   No CTL installed
2000/01/01 00:00:45:402   IP phone is in non-secure mode
2000/01/01 00:00:46:327   Succeed to get ATAD824BDBB0FA0.cnf.xml
2000/01/01 00:00:45:380   No CTL installed
2000/01/01 00:00:46:337   Succeed to get ATAD824BDBB0FA0.cnf.xml
2000/01/01 00:00:45:365   File Not Found : CTLSEPD824BDBB0FA0.tlv
2000/01/01 00:00:45:370   No CTL installed
2000/01/01 00:00:45:373   IP phone is in non-secure mode
2000/01/01 00:00:46:306   Succeed to get ATAD824BDBB0FA0.cnf.xml
2000/01/01 00:00:45:385   File Not Found : CTLSEPD824BDBB0FA0.tlv
2000/01/01 00:00:45:389   No CTL installed
2000/01/01 00:00:45:393   IP phone is in non-secure mode
2000/01/01 00:00:46:296   Succeed to get ATAD824BDBB0FA0.cnf.xml
2000/01/01 00:00:45:446   File Not Found : CTLSEPD824BDBB0FA0.tlv
2000/01/01 00:00:45:451   No CTL installed
2000/01/01 00:00:45:454   IP phone is in non-secure mode
2000/01/01 00:00:46:356   Succeed to get ATAD824BDBB0FA0.cnf.xml
2000/01/01 00:00:45:345   File Not Found : CTLSEPD824BDBB0FA0.tlv
2000/01/01 00:00:45:350   No CTL installed
2000/01/01 00:00:45:353   IP phone is in non-secure mode
2000/01/01 00:00:46:276   Succeed to get ATAD824BDBB0FA0.cnf.xml
2000/01/01 00:00:44:605   File Not Found : CTLSEPD824BDBB0FA0.tlv
2000/01/01 00:00:44:610   No CTL installed
2000/01/01 00:00:44:613   IP phone is in non-secure mode
2000/01/01 00:00:45:526   Succeed to get ATAD824BDBB0FA0.cnf.xml
2000/01/01 00:00:47:384   File Not Found : CTLSEPD824BDBB0FA0.tlv
2000/01/01 00:00:47:389   No CTL installed
2000/01/01 00:00:47:392   IP phone is in non-secure mode
2000/01/01 00:00:48:326   Succeed to get ATAD824BDBB0FA0.cnf.xml
2000/01/01 00:00:45:404   File Not Found : CTLSEPD824BDBB0FA0.tlv
2000/01/01 00:00:45:409   No CTL installed
2000/01/01 00:00:45:412   IP phone is in non-secure mode
2000/01/01 00:00:46:336   Succeed to get ATAD824BDBB0FA0.cnf.xml
2000/01/01 00:00:45:455   File Not Found : CTLSEPD824BDBB0FA0.tlv
2000/01/01 00:00:45:459   No CTL installed
2000/01/01 00:00:45:463   IP phone is in non-secure mode
2000/01/01 00:00:46:375   Succeed to get ATAD824BDBB0FA0.cnf.xml
2000/01/01 00:00:45:425   File Not Found : CTLSEPD824BDBB0FA0.tlv
2000/01/01 00:00:45:430   No CTL installed
2000/01/01 00:00:45:433   IP phone is in non-secure mode
2000/01/01 00:00:46:348   Succeed to get ATAD824BDBB0FA0.cnf.xml
2000/01/01 00:00:45:205   File Not Found : CTLSEPD824BDBB0FA0.tlv
2000/01/01 00:00:45:210   No CTL installed
2000/01/01 00:00:45:213   IP phone is in non-secure mode
2000/01/01 00:00:46:145   Succeed to get ATAD824BDBB0FA0.cnf.xml
Please check, where could be the issue.
What does your config file look like?  Grab the console logs as well.  Might need a packet capture to see if it is reaching out to CUCM.  Do you have the nodes defined by IP in CUCM under System->Server?
ATA status on call manager is rejected
Nodes are define by IP in Call Manager
Console logs are attached
ATA MAC D824BDBB0F19  IP 20.26.22.80
Your pictures didn't work.  Can you add them as attachments?
attached
Since it is getting rejected, you will need to pull the CallManager traces showing the device trying to register in order to see why CUCM is rejecting it.
