06-04-2012 09:14 AM - edited 03-16-2019 11:29 AM
I need a good and cheap attendant console for cme9.
please if somebody know a good one please let me know.
Thanks.
Solved! Go to Solution.
06-04-2012 10:06 AM
Hi Rafael,
Nice to hear from you as well my friend
I'm sorry...the link I gave you is for UC500 products, for CME it's called;
Cisco Unified CallConnector Operator
Deployment Options
Table 3. Deployment Options for Cisco Unified CallConnector Operator
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps7046/ps7274/data_sheet_c78-655141.html
So, for a single Operator Console no server would be required
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
06-04-2012 01:02 PM
All CME SCCP supported phones are supported by UCC.
06-04-2012 09:24 AM
Hi Rafael,
Have you looked into the Smart Call Connector Console
http://www.cisco.com/en/US/products/ps10865/index.html
Cheers!
Rob
06-04-2012 09:55 AM
Hello Rob,
long time without see your helpfull answers!..
one question, I have cme9 on a 2901. But Im using 100% sip implementation, 3905 sip phones.
Will the connector operator work for any type of phone?.
I I want use call connector operator for only one client, do I need purchase the call connector server?
Thanks.
06-04-2012 11:16 AM
Hi Rafael,
Unfortunately SIP Phones are not supported with Unified Call connector. Please refer to the data sheet below to see the supported phones:
Tere.
If you find this post helpful, please rate!
06-04-2012 12:53 PM
Sound weird that the datasheet only mention 7940G, 7960G, or 7970G Series models, mainly because that list are EOL ip phones. What about 7911, 7941, 7942, 7945???....
can somebody confirm that?.
Thanks.
06-04-2012 01:02 PM
06-04-2012 10:06 AM
Hi Rafael,
Deployment Options
Cheers!
Rob
06-04-2012 01:17 PM
Tere and Rob,
Why the datasheet refers only those eol phones? (7940G, 7960G, or 7970G Series models)
The phones listed refers to the ip phone used by the person who handle the callconnector application, right?.
My question is about the phones that the callconnector operator can handle (or monitor).
Can the callconnector Operator monitor and handle cisco sip phones?
Thanks.
06-06-2012 12:30 PM
its work for any 794x and 796x. for media. The application can monitor sccp and sip phones.
do you know if it works for ip communicator?
Thanks.
