auth fail ip phones
rchakchouk
hello,
after upgrading the pack software 8.6.1 of UC520 , the ip phones shows auth fail. how can i resolve this problem?
9 Replies 9
paolo bevilacqua
As indicated already in another thread.
It is enought to  use the search function to find many threads on the same subject, no need to open new ones.
Chris Deren
Perform factory reset on the phone or manually delete all certs.
HTH,
Chris
what do you mean by deleting all certs?
Under security --> trusted list delete CTL and ITL certs.
Chris
this is in CCA? i don't find the word CTL
Are you doing this on the IP phone?
Chris
i can' delete this on the ip phones and it shows in the phone CLT not installed.
OK, that was expected, what about the ITL?
Did you try facory reset of the phone?
Chris
ther is not ITL. not i didn't try the reset factory.
