It should be under the
System Call Handlers > Your_Call_Handler Basics > Edit > Greetings > Standard (or something else)
On that Greeting you should see a tab Recording , it is in that.
Please note that, it is a Java Applet, means it is very sensitive to your Java installation.
Please rate all helpful threads.
