ā07-18-2019 09:37 AM
Using CP-8811 for 3 party call control and registered in Broadsoft v21 sp 1
2 lines are registered on phone. Second line should be use to check the general voice mail.
Message key only dial line one voice mail number.
I want to set up ring down/Hot Dial to dial voice portal number (9999 or *62 ) as long as pick the VM line.
Solved! Go to Solution.
ā07-18-2019 11:05 AM
I guess I understand what you are looking for. Change dial plan on Ext 2 to:
(P0 <:9999>)
This should dial out 9999 as soon as you go offhook
ā07-18-2019 10:22 AM
I am not sure if I understand your question. You want two lines registered and use the second line to dial out to just voicemail?
ā07-18-2019 10:25 AM
Yes, Second line just dial out the specific number (9999 or *68) as long as go off hook.
ā07-18-2019 10:51 AM
You can configure second line as a speed dial to dial out 9999.
(P0 <:9999>)
ā07-18-2019 11:16 AM
