Auto select line 2 for outgoing calls 7941G CUCM 8.6
George Banuelos
Greetings,
Have a request for setting up Auto-select of line 2 on a 7941G for outbound calling when going off-hook.  The 'Always Use Prime Line' option is set to off, but this setting is used to allow atuomatic line selection for inbound calling and not outbound.  How can this be configured on CUCM 8.6?
Thank you,
George
"I believe that the greatest work of God has not been in the miraculous, nor in the spectacular, incomprehensible Creation, but rather I believe it was accomplished on the Cross where He Himself purchased the redemption of His Bride... the salvation of m
Rob Huffman
Hi George,
Although this feature is an option on some older PBX's like
the Nortel CS1000 it has never been available for CUCM
You could try opening PER to try and get this added in a future version.
Cheers!
Rob
"A smile relieves a heart that grieves"
- Stones
sure, how can this PER be submitted?
Rob Huffman
Hi George,
Only your Cisco account team (CAM & SE) can open a
PER (Product Enhancement Request) on your behalf. You
will need to work with them for this requst. I have seen this
requirement/need discussed here a few times so you're probably
not alone
Cheers!
Rob
- Stones
Thank you for the follow up!
