08-28-2013 03:59 PM - edited 03-16-2019 07:05 PM
Greetings,
Have a request for setting up Auto-select of line 2 on a 7941G for outbound calling when going off-hook. The 'Always Use Prime Line' option is set to off, but this setting is used to allow atuomatic line selection for inbound calling and not outbound. How can this be configured on CUCM 8.6?
Thank you,
George
08-29-2013 05:24 AM
Hi George,
Although this feature is an option on some older PBX's like
the Nortel CS1000 it has never been available for CUCM
You could try opening PER to try and get this added in a future version.
Cheers!
Rob
"A smile relieves a heart that grieves"
- Stones
08-29-2013 10:01 AM
sure, how can this PER be submitted?
08-30-2013 06:12 AM
Hi George,
Only your Cisco account team (CAM & SE) can open a
PER (Product Enhancement Request) on your behalf. You
will need to work with them for this requst. I have seen this
requirement/need discussed here a few times so you're probably
not alone
Cheers!
Rob
- Stones
08-30-2013 11:50 AM
Thank you for the follow up!
