03-03-2016 03:02 AM - edited 03-17-2019 06:07 AM
it's possible to enable/disable the beep when we have the phone with autoanswer with headset?
Paulo Ferreira
03-03-2016 03:13 AM
Did you check the Ring Setting option on the DN level and see if that helps.
Deepak
03-03-2016 03:48 AM
Hello Deepak,
thanks for you answer.
I check that option without success, the only options available are: disable, flash only, ring once, ring.
Paulo Ferreira
08-12-2016 03:09 PM
Hi Paulo,
What is the make and model of headset you're using?
-Drew Merritt
