01-06-2013 03:05 AM - edited 03-16-2019 03:00 PM
in cme express how to make autoattendant configuration
01-06-2013 03:16 AM
Hi Syed,
Since you haven't mentioned whether the voicemail system is a CUE, Unity or Unity Connection, I'll assume you are referring to CUE. Here are some docs you should go through which would help in this setup:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmevmail.html
HTH. Please rate helpful posts.
Harmit.
01-06-2013 06:02 AM
HI Harmit Singh
in cme express how to make autoattendant configuration with out unity express
01-06-2013 06:14 AM
Hi Syed,
Thanks for the clarification. The following link should serve your purpose:
https://supportforums.cisco.com/docs/DOC-16934
Please rate if helpful.
Harmit.
