Automatic Call Attend and Transfer
Faza
Dear Experts,
Please Find Enclosed Attachment
We have a cisco 2911 CME IP telephone system .There have 4 PSTN lines connected over the WIC Card. .Also More than 50 VoIP ephones are connected over the Local area Network.
Recent admin were configured when some calling from outside the premises to over the PSTN Line. The Line will be automatically answered and the caller is able to listen a prerecorded voice message. If the caller enter the internal extension number after the voice message the call will be transfer to the number.
how to set If the caller didn’t enter any extension it calls will be transfer to particular extension.
Let me know how to set above feature in cisco 2911 Router
voice-card 0
voice service voip
ip address trusted list
ipv4 172.30.144.0 255.255.255.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
fax protocol t38 nse force version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
sip
registrar server expires max 1200 min 300
voice register global
mode cme
source-address 172.30.144.2 port 5060
max-dn 20
max-pool 10
load 9971 sip9971.9-1-1SR1.loads
timezone 31
tftp-path flash:
file text
create profile sync 0004045871754718
ntp-server 172.30.144.2 mode directedbroadcast
camera
video
control-plane
voice-port 0/0/0
supervisory disconnect dualtone mid-call
cptone BE
timeouts call-disconnect 0
timeouts wait-release 1
connection plar opx 500
impedance complex2
description ***011-5405171***
caller-id enable
caller-id alerting line-reversal
caller-id alerting dsp-pre-allocate
ial-peer voice 511 voip
destination-pattern 500
session target ipv4:172.30.144.2
dtmf-relay h245-alphanumeric
codec g711ulaw
dial-peer voice 500 voip
service aa
incoming called-number 500
codec g711ulaw
dial-peer voice 100 voip
destination-pattern 200
progress_ind setup enable 3
modem passthrough nse codec g711ulaw
session target ipv4:172.30.144.36
incoming called-number .
codec g711ulaw
fax rate disable
no vad
With Best Regards,
Azaf
HARIS_HUSSAIN
Try Below see if that helps :
Just add the destination which you want the call to send as voicemail Number using below command.
param voice-mail <number>
Please rate and mark correct if helpful
Let us say you want to send the call to  139 just change as below.
application
 service aa flash:its-CISCO.2.0.2.0.tcl
  paramspace english language en
  paramspace english index 0
  param operator 121
  paramspace english location flash:
  paramspace english prefix en
param voice-mail 139 param aa-pilot 500 param max-extension-length 3
HARIS_HUSSAIN
application
  param operator 121
Dear Mr.Haris Hussain,
Please Find Enclosed Attachment.
Thanks For your quick respond. Its highly Appreciated.
However I execute below command getting below warning.
Warning: Parameter operator is not been registered under AA name space
with best regards
Azaf
Does the command take effect or skiped
 What are we trying to achieve here!
Yes, during the command execution it was shown Message as below.
“Parameter operator is not been registered under AA name space"
However the Number has assigned For the AA
which means the issue has been resolved.
I’m seeking another matter Too
There have a welcome voice message. The Name Belongs to "en_welcome.au" and it’s existed in Flash Memory. We need to update with a new voice. The file has downloaded using by "copy flash tftp:" Command
Let me know how upload new audio file into flash Also what is the maximum size or Length of the audio File
Should i delete the old audio file from the Flash memory or there have required any other command?
Your valuable comments its highly appreciated.
With best regards
Azaf
