02-03-2015 06:23 AM - edited 03-17-2019 01:49 AM
Hi folks
I'm working on a fresh install of CUCM 10.5.2 with local and LDAP End Users.
Now I like to add at least End User Rights automatically to the newly imported LDAP Users.
Even if I add an new local user, I like that they have "Standard CCM End User Rights" added per default, if it's possible.
Every help is more than welcome. Thank you very much.
Kind regards
P.Blumenthal
Solved! Go to Solution.
02-03-2015 06:37 AM
Navigate to System -> LDAP -> LDAP Directory and then select your LDAP syncronization agreement. A little more than halfway down the page there is a "Group Information" section where you can assign the "default rights" given to each LDAP user that gets imported.
rh
02-03-2015 06:37 AM
rh
02-03-2015 08:02 AM
Hi Ryan
Right, is that easy. Fu**
Thank you
Cheers,
Pascal
