Automatically added User rights to LDAP imported Users
Hi folks
I'm working on a fresh install of CUCM 10.5.2 with local and LDAP End Users.
Now I like to add at least End User Rights automatically to the newly imported LDAP Users.
Even if I add an new local user, I like that they have "Standard CCM End User Rights" added per default, if it's possible.
Every help is more than welcome. Thank you very much.
Kind regards
P.Blumenthal
Ryan Huff
Level 4
Level 4
Navigate to System -> LDAP -> LDAP Directory and then select your LDAP syncronization agreement. A little more than halfway down the page there is a "Group Information" section where you can assign the "default rights" given to each LDAP user that gets imported.
rh
Ryan Huff
Level 4
Level 4
rh
Hi Ryan
Right, is that easy. Fu**
Thank you
Cheers,
Pascal
