AXL SOAP ASP
mamaral
Where can i get an asp to do an custom corporate directory?
The objective is to create the same corporate directory has the one that comes with the cucm, but the awnser gives back the department. So i need it to query the cucm using axl/soap.
TKX in advanced!
Miguel
5 Replies 5
Jitender Bhandari
Hi Miguel,
See below for help
https://supportforums.cisco.com/discussion/10944226/custom-directory
(Rate if it helps)
JB
Hi!
Tkx for your response, but the corporate directory that i need is to make querys at the cucm using axl soap. I do not want to query an AD.
The problem is that i need the query response to give the department information also.
Best regards,
Miguel
So are you pointing one CUCM to another for corporate directory services?
No, I need an costum web service that points to the same cucm server. The objective is to costumize the query result.
Here is some information on 3rd party provisioning application with your CUCM using Cisco AXL
http://info.stack8.com/blog/integrate-applications-using-cisco-unified-communications-manager
I would recommend to open a query at Devnet for this helps as those people deals in these kinda requests.
https://developer.cisco.com/site/devnet/home/index.gsp
(Rate if it helps)
JB
