11-30-2010 06:20 AM - edited 03-16-2019 02:11 AM
I´ve a config of B-ACD that is not working on a Cisco 1861. But the same cnfig works fine on others Cisco 1861. Here it is:
application
service autoatt app-b-acd-aa-2.1.2.2.tcl
paramspace english index 1
param menu-timeout 6
param second-greeting-time 10
paramspace english language en
param max-time-vm-retry 0
param max-time-call-retry 60
param voice-mail 99
param aa-pilot 330030
param max-extension-length 4
param number-of-hunt-grps 2
paramspace english location flash:
param dial-by-extension-option 1
param handoff-string autoatt
param welcome-prompt _bacd_welcome.au
param call-retry-timer 5
paramspace english prefix en
param service-name queue
service queue app-b-acd-2.1.2.2.tcl
param queue-len 1
param aa-hunt3 5572
param queue-manager-debugs 1
param aa-hunt2 5570
dial-peer voice 1 pots
service autoatt
incoming called-number .*
port 0/1/0
dial-peer voice 2 pots
service autoatt
port 0/1/1
The situation is this:
1.- The call arrives from the PSTN through the FXO 0/1/0 or 0/1/1
2.- Then dial-peer 1 and 2 triggers the service autoatt
But now the service is not triggered, Ive tried with debug voice application media service, and nothing appears...
The FXO are working fine for outgoing calls, using a debug vpm signal I can see the call arriving to the FXO.
Any idea?
TIA
Andres Pasten
Adexus S.A.
Solved! Go to Solution.
11-30-2010 11:08 AM
Actually the pots DP with port configuration is right in principle. It triggers the service directly on the pots DP.
That is a good thing since it avoids the VoIP loopaback, slightly improving response time and voice quality.
Then it has to seen why it doesn't work, it can be an issue with clid that sometime takes precedence. It can be worked out, however.
11-30-2010 10:12 AM
I wouldn't configure the FXO ports that way.
Put the pilot for the AA on a dial peer like this:
dial-peer voice 2501 voip
service aa
destination-pattern 1005
session target ipv4:10.1.10.10
incoming called-number 1005
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
If you need to get the FXO ports to the dial peer, use a PLAR to point it to the dial peer.
11-30-2010 10:32 AM
Hi Clifford,
and that IP 10.1.10.10, is the IP address of the gateway running the B-ACD?
so the dial-peer is targeting the same gateway?
Please let me know.
11-30-2010 10:56 AM
It's the IP address of the loopback adapter on the BACD router.
11-30-2010 11:08 AM
12-06-2010 11:36 AM
Finally the config was fine, we tested it on another Cisco 1861 and it worked fine. We replace the gateway and the issue was solved. Now I´m waiting for that 1861 to check what is wrong with it.
Thanks anyone for the support!!
