Background Wall Paper in CM8
yswon
Is there anyway for us to upload the background image and xml file into CM8, and configure the URL in order for ip phone to have the specific background/wallpaper when first bootup
Jaime Valencia
No that's not possible
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
markie187
You cannot have the image boot up with the phone. You need to manually set it by pressing settings>User Preferences>Background images
To load the image onto the phone you need a tftp client on your machine which you can grab and edit the list.xml file with, you need the images in the right format then upload to the right directory.
http://atc.go0se.com/?p=330
Is it possible that we use a external server to achieve this objective?
If you want to use an external TFTP server check this link.
https://supportforums.cisco.com/message/3276124
Nitesh
PS:Rate helpful posts
